I'm attempting to create a model that will run through all the surfaces with the same description name, analyze the obstacles against the selected OIS surface, then pump out a feature class of the obstacles with the Description at the end of the feature class name (in this case, it would be 3 point feature classes exported from the model). I was able to use the Iterate Row Selection tool to run through the rows in the multipatch, but it's not wanting to run the Analyze Runway Obstacles tool in the model builder. Is it possible for me to run a model that will create separate point feature classes?
