Following on previous post, I imported a bunch of tables into GDB using ExcelToTable(). As such the workspace was set to the location of my Excel Files. Tables import fine.
When try make a feature using arcpy.MakeXYEventLayer_management later in script, I get an error indicating the table doesn't exist, and the layer already exists. Is this how I have the workspace set, or am I really messing up some other way?
import pandas as pd
import arcpy, os, re
# Variables
arcpy.env.workspace = r'C:\Data\working\EBS16\raw_sonar_files'
outputGDB = r"C:\Data\working\EBS16\EBS_16_analysis_display\default.gdb"
finalOUT = r"C:\Data\working\EBS16\EBS_16_analysis_display\default.gdb\em710vals\em50_"
spref = arcpy.SpatialReference(26903)
try:
for file in arcpy.ListFiles("*.xlsx"):
f = os.path.join(arcpy.env.workspace, file)
# Get excel sheets
sheetNames = pd.ExcelFile(f).sheet_names
# iterate through sheets
for sheet in sheetNames:
# Replace non alphanumeric characters with underscore
sheetName = re.sub(r'[^0-9a-zA-Z]+', r'_', sheet)
# create name for temp layer in XY event theme
outLyr = sheetName + '_lyr'
# Convert sheet to GDB table
arcpy.conversion.ExcelToTable(f, os.path.join(outputGDB, sheetName), sheet, 1, '')
# make XY Layer
arcpy.MakeXYEventLayer_management(sheet,'easting', 'northing', outLyr, spref)
outFeat = finalOUT + sheetName # naming convention
arcpy.management.CopyFeatures(outLyr, outFeat) # make lyr permanent
except Exception as e:
print("Error: " + e.args[0])
