I am trying to pass some attributes from my layer to another but I am having an issue is with passing attributes from field 'Field4', the attributes from the layer sjpoints field 'Field4_1' doesn't match so the fc_dest layer 'Field4' and doesn't get updated.
The issue is FIELD4_1 has abbreviations and fc_dest has domains. How can modify my current code to check that field and if it has certain abbreviations to update with certain text, or would it be best to do a separate updatecursor and if so how can I pass the nest dictionary from the spatial join to update the fc_dest layer?
sjpoints - the spatial join has this
| TARGET_FID | FIELD4_1 |
32145 | MH |
13245 | SFR |
fc_dest - I need this
| OID | FIELD4 |
| 32145 | MOBILE HOME |
| 12345 | SINGLE FAMILY RES |
sourceFieldsList = ['TARGET_FID', poly,'Field1_1','Field2_1','Field3_1','Field4_2','Field4_1','Field5_1','Field6_1']
# define the field list to the original points
updateFieldsList = ['OID@', Pnt,'Field1','Field2','Field3','Field4','Field5','Field6]
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(ptSelection, parcel, sjpoints)
with arcpy.da.UpdateCursor(fc_dest, updateFieldsList) as updateRows:
for updateRow in updateRows:
# store the Join value of the row being updated in a keyValue variable
keyValue = updateRow[0]
# verify that the keyValue is in the Dictionary
if keyValue in valueDict:
# transfer the values stored under the keyValue from the dictionary to the updated fields.
for n in range (1,len(sourceFieldsList)):
updateRow[n] = valueDict[keyValue][n-1]
updateRows.updateRow(updateRow)
