I have SDE.ST_GEOMETRY polyline FCs (tables) in an Oracle 18c geodatabase.
I'm building various SQL queries on the tables. It would help if I could use Oracle Spatial/SDO_GEOMETRY functionality like Spatial's linear referencing functions.
- Unfortunately, it's not possible for me to change the datatype in the table from SDE.ST_GEOMETRY to MDSYS.SDO_GEOMETRY, due to existing dependencies on the ST_GEOMETRY shape column.
- Also, it seems like ArcGIS only supports a singe geometry column per table. So it's not like I can just add a SDO_GEOMETRY column to the table, without risking problems in ArcGIS.
Alternatively, what are my options for generating a separate SDO_GEOMETRY column so that I can use Oracle Spatial functions?
For example:
- Convert from ST_GEOMETRY to SDO_GEOMETRY in a query on-the-fly.
Downside: the query is complicated/fragile/slow. I don't want to make the conversions every time the queries are used. - Add an invisible SDO_GEOMETRY column to the table. Update the column with a db trigger. Add a spatial index.
Downside: Invisible SDO_GEOMETRY columns aren't supported in Oracle. Also: Idea: Support invisible SDO_GEOMETRY columns. - Create a parallel table that has a common ID column and a SDO_GEOMETRY column. Create a trigger on the ST_GEOMETRY table that updates the parallel table after INSERT, UPDATE, or DELETE. Or use calculation attribute rules in ArcGIS Pro to do something similar.
Downside: Adds extra tables/complexity that need to be managed. Joining from the ST_GEOMETRY table to the parallel SDO_GEOMETRY table might be slow for large datasets. - Parallel materialized view with an SDO_GEOMETRY column.
Downside: A different department would need to create and manage the the materialized view, since GDB data creators/owners don't have CREATE MATERIALIZED VIEW privileges. (It's always a pain when you can't manage your own stuff.)
Does anyone have any thoughts on those options? Or are there any other options that I've overlooked?
Related: Choose spatial column when adding data with more then one spatial column
