I'm using ArcPro I have a layout that we use for a map series. The basemap of the map that feeds the mapframe is the USA Topo Maps tile dataset from the Living Atlas. In the map that feeds the layout I have applied a layer effect to turn the basemap grayscale. (Luminosity blending effect, map set to 50% transprency)
If I then create a Map Series, the PDF exports does not apply the layer effect, the base layer shows in full color.
If I create an independent layout--in this case simply turn of the Map Series functionality--the exported map does retain the layer effect.
This appears to be a bug. Or at least the behavior is inconsistent. I would think that map in series should be able to retain the layer effects the same as a stand-alone layout.
Am I missing something? Is there a workaround outside of copying and making an independent layout for every sheet?
Thanks for your help.
