I have a map service published through ArcGIS Server. The map service has 3 layers and the layers have sublayers. I am trying to transition from Esri's JSAPI 3.x to 4.x. In 3.x, I used to call a ArcGISDynamicMapServiceLayer and use layer.setInfotemplates to add popups to the map. I have a few layers, so I do not want to use feature layer to create popups for the sake of performance.
Can I call popups using MapImageLayer in JS API 4.x?
The codes I used in 3.x is as follow:
var popupTemplate = new PopupTemplate({
"title": "Row Flags",
fieldInfos: [
{fieldName: "GPS_Date", visible: true, label: "Date Collected", format: {dateFormat: "shortDate"}},
{fieldName: "GNSS_Heigh", visible: true, label: "Z-value"},
{fieldName: "Feature_Description", visible: true, label: "Description"}
});var dynamicLayer = new ArcGISDynamicMapServiceLayer("https://RESTURLEndpoints", {
"imageParameters": imageParameters,
opacity: 1
dynamicLayer.setInfoTemplates({
1: {infoTemplate: popupTemplate},
2: {infoTemplate: popupTemplate2},
4: {infoTemplate: popupTemplate3},
5: {infoTemplate: popupTemplate4},
7: {infoTemplate: popupTemplate5},
8: {infoTemplate: popupTemplate6},
9: {infoTemplate: popupTemplate7},
10: {infoTemplate: popupTemplate8}
});Thanks,
