I need assistance with my script. Can anyone point me in the right direction?
I'm attempting to overwrite a feature layer with data from a CSV file, both of which are hosted on my portal on ArcGIS Online.
My code is displayed below.
When I run the code to perform the overwriting process, I get the following error message:
Exception: Error while analyzing File Geodatabase 'Hospitals_0.csv' Unable to extract 'file geodatabase' Invalid File Geodatabase, missing gdbtable or gdbindexes file.
(Error Code: 406)
# import libraries
from arcgis.gis import GIS
from arcgis import features
import pandas as pd
import os
import datetime as dt
import shutil
from arcgis.features import FeatureLayerCollection
gis = GIS("home")
""""Align Current Working Directory for Notebook and Scheduled Tasks
By default, Notebook is '/arcgis' and Scheduler is '/home/arcgis/data/overwrite"""
os.chdir( "/arcgis") # match scheduler to notebook
data_path = "/arcgis/home/data/overwrite"
if not os.path.exists( data_path):
# create work folder
os.mkdir( data_path)
# confirm path exists
if os.path.isdir(data_path):
print("Directory already exists")
else:
print("Creating directory for you")
# Item Added From Toolbar
# Title: Python Testing for Hospitals | Type: Feature Service | Owner: bayparkds
primary_overwrite = gis.content.get("778f98bd191a4bc6921885fae2b5109e")
primary_overwrite
# assign path variables for data
# MCH_Hospitals.csv contains the initial incomplete dataset which is published as a feature layer
csv_file = 'Hospitals_0.csv'
# assign variable to current timestamp to make unique file to add to portal
now = int(dt.datetime.now().timestamp())
# read the csv data directly
my_csv = os.path.join(data_path, csv_file)
# read the initial csv
hospitals_df_1 = pd.read_csv(my_csv)
hospitals_df_1.head()
# add the csv into content
item_prop = {'title':'Python Testing for Hospitals' + str(now)}
csv_item = gis.content.add(item_properties=item_prop, data=my_csv)
csv_item
# update the item csv name
item_prop = {'title':'Python Testing for Hospitals'}
csv_item.update(item_properties = item_prop,
thumbnail=os.path.join(data_path, csv_file))
csv_item
primaryoverwrite_flayer_collection = FeatureLayerCollection.fromitem(primary_overwrite)
# call the overwrite() method which can be accessed using the manager property
primaryoverwrite_flayer_collection.manager.overwrite(os.path.join(data_path, 'Hospitals_0.csv'))
