The GeometryEngine.Cut method is inconsistent with which side of the result gets returned first, meaning I have to do additional analysis to figure out which result item is on which side. Coming from ArcObjects, I'm accustomed to the first result being the left side and the second being the right, and that expectation appears to hold based on the documentation's code example. However, the first value returned when cutting a polygon is sometimes the left side and sometimes the right. The order is always the same for a given input, but different inputs may swap the order.
In the image below (created in GeoGebra), one set of inputs/outputs is in blue; the other in orange. Both cut lines are oriented southeast, and the points are the northernmost point of each result's side. The orange line (angle ~330 degrees) returns the left side at index 0, but the blue line (angle ~334 degrees) returns the right side at index 0.
Is the intent for developers to do further analysis to determine which result is the left side? Is there a "rule" for which side is at index 0?
