I'm creating a map layout in C#. I have 2 map frames; one is the main frame, the other is an area of interest frame that needs an extent indicator. I'm able to create everything on the layout, except I can't seem to figure out how to plug the CIMExtentIndicator definition into the CIMMapFrame Element.
Here's the relevant code:
//MapFrame Creation
Coordinate2D ll = new Coordinate2D(0.25, 1.3);
Coordinate2D ur = new Coordinate2D(10.75, 8);
Envelope mapEnv = EnvelopeBuilder.CreateEnvelope(ll, ur);
//AOI map frame
Coordinate2D ll_aoi = new Coordinate2D(10.05, .25);
Coordinate2D ur_aoi = new Coordinate2D(10.72, 1.25);
Envelope mapEnv_aoi = EnvelopeBuilder.CreateEnvelope(ll_aoi, ur_aoi);
MapFrame newMapFrame = LayoutElementFactory.Instance.CreateMapFrame(newLayout, mapEnv, newMap);
newMapFrame.SetName("Main Map Frame");
MapFrame AOI = LayoutElementFactory.Instance.CreateMapFrame(newLayout, mapEnv_aoi, aoiMap);
var cimAOI = AOI.GetDefinition() as CIMMapFrame;
AOI.SetName("AOI Frame");
CIMStroke extentOutline = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 1.0, SimpleLineStyle.Solid);
CIMPolygonSymbol extentPoly = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.BlackRGB, SimpleFillStyle.Null, extentOutline);
var extent = new CIMExtentIndicator
SourceMapFrame = "Main Map Frame",
Symbol = extentPoly.MakeSymbolReference(),
cimAOI.ExtentIndicators[0] = extent;
AOI.SetDefinition(cimAOI); //exception thrown: the Object is null
I notice that the CIMExtentIndicator property on the CIMMapFrame element contains square brackets [], meaning it requires an index integer, but I'm just not sure how to form the correct syntax.
I'm using VS2019. No build issues occur before running the code. If I comment out the extent indicator code, everything works perfectly.
