Hello- wondering if anyone knows if it is on the roadmap to allow the distributed collaboraitions to support data sharing by copies larger than 1GB (or if there is a way to override that default in an AGOL to Enterprise 10.91 collaboration)?
https://enterprise.arcgis.com/en/portal/latest/use/common-questions-for-distributed-collaboration.htm
"The feature layer exceeds the maximum item size of 1 GB, which will cause the item to be shared as a reference. To verify, enable INFO level portal logs and look for the log entry that indicates the size of the shared feature layer data item."
Appreciate any thoughts on this one.
Regards,
Sam
