Hello. I am using a map service for parcels from the County of the municipal organization that I work for. Once I added "data from path", I was able to select by attribute but I'm not able to export the selected parcels into my working file GDB. The only thing I was able to do was "create layer from selected" which still points back to feature service and the data/export data option is grayed out. Is there not a way to do this in Pro?
