have a polygon file in form of a fishnet. Also another feature class with polygons named Trawl_Buffers. There is a unique field within Trawl_Buffers based on YEAR. I'd like to create a script to run a selection on YEAR, and then perform a union analysis with the fishnet polygon for each YEAR. So the desired output would be "Trawl_Buffers_union2003", "Trawl_Buffers_union2004" etc. I have a function that will get me the unique list of the years, and puts them in a list which i called vals.
Then seems I need to run a for loop over this list of unique years, create a temporary selection, then use that as input for the union, but I am having trouble implementing the query process.
Here is where I started, but seriously tripping:
import arcpy
#Set the data environment
arcpy.env.workspace = r'C:\Data\working\AK_Fishing_VMS\2021_Delivery\ArcPro_proj\ArcPro_proj.gdb'
trawlBuffs = r'C:\Data\working\AK_Fishing_VMS\2021_Delivery\ArcPro_proj\ArcPro_proj.gdb\buffers\buffers_testing'
fishnet = r'C:\Data\working\AK_Fishing_VMS\2021_Delivery\ArcPro_proj\ArcPro_proj.gdb\fishnets\vms_net1k'
unionOut = r'C:\Data\working\AK_Fishing_VMS\2021_Delivery\ArcPro_proj\ArcPro_proj.gdb\unions\union'
# function to get unique values for the YEAR field found within the trawlBuffs fc
def unique_values(table, field):
with arcpy.da.SearchCursor(table, [field]) as cursor:
return sorted({row[0] for row in cursor})
# Get the unique values for the field 'YEAR' found within the 'trawl_buffs' featureclass table
vals = unique_values(trawlBuffs, "YEAR")
# Create a query string for the selected country
yearSelectionClause = '"YEAR" = ' + "'" + vals + "'"
#loop through the years, create selection, union, make permanent
for year in vals:
year_layer = str(year) + "_union"
arcpy.MakeFeatureLayer_management(trawlBuffs, year_layer)
arcpy.SelectLayerByAttribute_management(year_layer, "NEW_SELECTION", "\"YEAR"\" = %d" % (year))
arcpy.Union_analysis(fishnet, year_layer , unionOut)
arcpy.CopyFeatures_management(year_layer, "union_" + str(year))
