I'm using survey123 connect v 3.13.251 and survey123 field app v 3.14.237 on iOS 15.1
The survey requires an address and photo. It also has a reference map in the linked content tab.
The address is validated with a custom locator. I'm using pulldata for x, y and location fields to map the data. However the points are showing from the location where the picture was taken and not based on the address, when the geopoint for the reference map is in the survey. The bind::esri:fieldType is set to null for the map.
Are there settings for recording photo location that should be turned off? Enclosed is the xlsx form.
Alicia
