I have created buffers that I now want to intersect with a layer. My problem is that the area inside the buffer doesn't match the theoretical area for a circle of that radius. I have the same deviation for every buffer. All coordinate systems are the same. The layer I'm using is definitely gapless (I checked that). The buffers that I use for intersecting have the correct area.
I need the correct area in the buffer to be able to continue with my task. Unfortunately I'm clueless.. I would be grateful for ideas and help.
