I am writing a pipeline script that gets data from different sources using post requests, adds them to a geodataframe and processes the data using Geopandas functions. Then I need to add the result to AGOL.
I don't use local files, everything is in memory.
Can I use gis.content.add to add a geojson dictionary to AGOL? Or any other in memory data like a feature set..
I have been trying this:
gis=GIS("https://arcgis.com", username, password)
json_gdf=gdf.to_json()
data_properties = {
'title': 'new_test',
'description': 'test',
'tags': 'test',
'type': 'GeoJson'
flayer=gis.content.add(data_properties, json_gdf)
I get the following error:
File "/mnt/c/Users//Documents/Github//.venv/lib/python3.8/site-packages/arcgis/gis/__init__.py", line 5141, in add
itemid = self._portal.add_item(
File "/mnt/c/Users//Documents/Github//.venv/lib/python3.8/site-packages/arcgis/gis/_impl/_portalpy.py", line 362, in add_item
raise RuntimeError("File(" + data + ") not found.")
In a way it makes sense, because ContentManager.add expects the following formats:
"Content can be a file (such as a service definition, shapefile, CSV, layer package, file geodatabase, geoprocessing package, map package) or it can be a URL (to an ArcGIS Server service, WMS service, or an application)."
What are my options here?
I also tried adding the geodataframe to AGOL directly using spatial.to_featurelayer - it works, but the field names are messed up, since that tool uses a shapefile as an intermediary (e.g. "SOURCE_FEATURE" becomes "source_fea"). That means I cannot append that data to an existing feature layer without having to write hundreds of field mapping rules.
NOTE: edit_features is not an option, the data is too big, and even chunked, it takes too long to add (and times out in Azure, but that's another story).
