Hi
I use an arcade expression in my field map feature popups to build a link to a survey 123 form, the link passes two attributes from the map feature into two responses in the form.
As of this morning (24/02 0900 GMT) I've had reports from some surveyors that whilst the link is opening the correct survey form it is no longer passing the attributes into the survey responses.
I was able to replicate the error on my own device after updating survey 123 to version 3.14. I was unable to replicate on version 3.13
The link has been working fine for the last six weeks or so, and I have been using a similar expression in my other surveys for the last year or so with no problems. I was wondering if the recent update may have altered the way I need to build the linkning url in field maps? Couldn't spot anything in the help docs
The link constructed from the arcade expression in Field Maps is given below, I don't encode the URL.
https://survey123.arcgis.app/?ID=[FORMID]&field:prSiteType=[SITETYPE]&field:prExistingSiteSuperName=[SITENAME]
EDIT: The first response in the url is being passed correctly into a select_one type question the second response is not being passed into a select_one_from_file or text type question (the type is dependent on the first response)
