I am trying to write a script that will take different permutations of the word Null and convert them to true database Nulls. I have users populate 'Null', 'NULL' or similar, and I need to convert these to true Nulls.
I have a list of the different permutations and a geodatabase with several feature classes. I'm trying to loop through my list and compare against all string values in all feature class. If there is a match, convert the string to the true Null.
I am getting an invalid syntax error on line 26:
row = [None if i in nullList else pass for i in row]
If I replace pass with print ('Test') it changes every value to Null. Any ideas?
import arcpy
import os
import time
inputGDB = r'C:\Test_null.gdb'
# Set workspace to input GDB
arcpy.env.workspace = inputGDB
nullList = ['', ' ', ' ', ' ', '-', '--', '---', '<Null>', '<NULL>', 'Null', 'NULL', '”Null”', '”NULL”']
datasets = arcpy.ListDatasets(feature_type='feature')
datasets = [''] + datasets if datasets is not None else []
# Loop through all feature classes
print('Reading Feature Classes...')
for ds in datasets:
for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
# Build a list of all TEXT/String Fields where NULL values are allowed
fieldList = [i.name for i in arcpy.ListFields(fc) if i.type == 'String' and i.isNullable is True]
# Iterate through each row and execute the clean
with arcpy.da.UpdateCursor(fc, fieldList) as cursor:
for row in cursor:
cursor.updateRow(row)
print('Done.')
