Goodafternoon,
I've made a quick ModelBuilder to calculate a field within a feature layer. The layer is hoasted on ArcGIS online and data is changed on a daily base. The ModelBuilder works, due the fact the calculation is made when running the tool immediately.
The error is when setting a schedule. The schedule gives no response and isn't running after the time is set:
Some more information:
- Working with the latest ArcGIS Pro
- Layer is added to the current map but I also tried by referring to the online feature set (both options runs the ModelBuilder immediately)
- Already tried this solution: https://community.esri.com/t5/arcgis-pro-questions/scheduled-tools-no-longer-running/m-p/1057138#M40846
- History is not given any information
If you have any idea, it would help a lot.
Regards, Marius
