Currently, when you click the Dataset's View Metadata button, the item's metadata is displayed.
Eg: https://www.arcgis.com/sharing/rest/content/items/8b5b4f2777a84b67b8130c3ca5009107/info/metadata/metadata.xml?format=default&output=html
However, if there is a Feature Service item, there is usually more than one layer inside. These sublayers have their own metadata, describing the data of each layer.
Eg: https://services9.arcgis.com/UILu2wREgFBEuDZW/arcgis/rest/services/AD_Address_Brussels_Belgium_AD_demo/FeatureServer/0/metadata?format=default&f=html
In addition, when publishing Enterprise Geodatabase data by reference (using ArcGIS Enterprise services), the metadata of each layer within the service is linked to the metadata within the geodatabase, which is great.
Unfortunately, this service-level metadata is not available in the ArcGIS Hub data catalog because it references item metadata.
Is there any development planned in this area?
Matej
