Hello! I recently made a survey with Survey123 and connected it to a map in ArcGIS Online. I understand that the map should update every time a new survey is submitted. However, I joined two layers in the map so that the survey data can be analyzed in the context my farm's pasture areas, and I do not know if the survey data will also update through the join. Does new survey data automatically get incorporated into analyses in an ArcGIS Online map, or do I need to constantly update the map manually by rejoining the layers and re-performing the various analyses with the joined layer?
Thank you for your help!
