Hi everyone,
I have a properties feature class and want to use this to create a kml file for each property and store it in the related region folder. I created a python script, but it put all the kml files in one folder and the rest are empty.
Could you please help me fix my script?
Maryam
import arcpy
import os
# settings
inputFC = r"\\D\Asset.sde\DBO.asset"
field_name=["Property_code","Property_Name","Region"]
output_location = r"\\D\Country\KML"
print "Starting"
# create list of unique properties codes and regions
lst_property = []
lst_regions= []
cursor = arcpy.SearchCursor(inputFC)
for row in cursor:
lst_property.append(row.getValue(field_name[0]))
lst_regions.append(row.getValue(field_name[2]))
del cursor
del row
lst_property = list(set(lst_property))
lst_regions = list(set(lst_regions))
for regions in lst_regions:
field1 = arcpy.AddFieldDelimiters(inputFC, field_name[2])
where ="\"{0}\" = '{1}'".format(field1, regions)
folder=os.path.join(output_location,regions)
if not os.path.exists(folder):
os.makedirs(folder)
folder=r"{}\{}".format(output_location,regions)
#loop through properties
for Properties in lst_property:
field = arcpy.AddFieldDelimiters(inputFC, field_name[0])
where ="\"{0}\" = '{1}'".format(field, Properties)
arcpy.MakeFeatureLayer_management(inputFC, "lyr", where)
kmz_file = os.path.join(folder,"{0}.kmz".format(Properties))
arcpy.LayerToKML_conversion("lyr", kmz_file)
