Hello! I am not sure if this is the correct Community ''folder'' where to post this, but I have a question relating to the wonderful workflow as demonstrated in this video Inspection Workflows Part 2: Web Map Creation & Dynamic Symbology by @EricWagner1
Two questions:
1) Is it possible to Access the water utilities Symbology also on the new Map Viewer? I see it neatly in the Classic..
2) Is it just me or when using the same method of IIF+DateDiff as to define symbology for points that have been inspected recently and those that have to be inspected - it works only in the Map Viewer Classic? Is it because the Layer View is added to the map? I tried a workaround - created layer view by Join Analysis and added it to the Map Viewer Map. Used the same Arcade that is in the demonstration. Worked great for the Map Viewer Classic Map. Ignores the second part of the expression in Map Viewer.
I would be happy if anyone could give a comment if this is how it's supposed to be for now.
Cheers!
