I have a script that takes in lot, long values (in decimal degrees) and determines whether the points are contained within a polygon in another feature class. I assume I have to create a point object and get it into the same coordinate system as the polygon, but the projection comes back empty (no points). I don't fully understand all the ins and outs of projections so hopefully I'm doing something obviously incorrect here.
x = -88.155675
y = 43.223869
f_cs = 'WGS 1984 Web Mercator (auxiliary sphere)'
t_cs = 'NAD 1983 UTM Zone 16N'
xform = 'WGS_1984_(ITRF00)_To_NAD_1983'
pt = arcpy.Point(x,y)
pg = arcpy.PointGeometry(pt, arcpy.SpatialReference(f_cs))
pgp = pg.projectAs(t_cs, xform)
print (pgp.firstPoint)
