Hi All,
What is best possible solution to provide FieldMaps users capability to see basemap+data and collect data in offline mode, if I have,
1)An online 3rd party map service for basemap
2)Sync enabled feature service (data hosted in EGDB) so that some smart forms can be designed.
I could find that
1)FieldMaps doesnt have option of using any polygon FC to generate 'offline areas' and I can draw only 16 areas.
2)WMS not supported for offline (Requirements—ArcGIS Field Maps | Documentation) so I could try MMPK but MMPK cant be used as user cant collect data with MMPK.
3)Cant use tile packages because only maps that contain local data can be cached using the tile package tools in ArcGIS Pro. Online services, such as tiled map services, are not supported. Attempting to package maps that contain online services will result in an error.(Share a tile package—ArcGIS Pro | Documentation)
Thank you.
