I am taking over a script from someone who has since retired. This script is used to create pdf documents of quarter sections from a map series created by data driven pages (ArcGIS 10.7). On the pdf there are map notes (among others as you can see below) from a feature class called NoteFeatures. When I try to run this script I keep getting an List Index Out Of Range error. Im still somewhat of a novice at Python so I am not sure what I am missing.
import arcpy, os, sys
# Get the data driven pages object from your mxd
# You will use this to export your pages
mxd = arcpy.mapping.MapDocument(r"C:\Users\SShenbe1\Desktop\Project\VMPrinting4.mxd")
ddp = mxd.dataDrivenPages
# Get the layer you are using as an Index Layer
# In this case the layer is in the data frame "Layers" and called "TWGrid3"
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
gridLayer = arcpy.mapping.ListLayers(mxd, "TWGrid3", df)[0]
# Get the layer for the feature class used to indicate inset map locations
# This needs to be in the same data frame as your index layer
# In this case the layer is in the data frame "Layers" and called "DetCircles2"
# First, make a layer from the feature class "DetCircles2"
arcpy.env.workspace = "C:\Users\SShenbe1\Desktop\Project"
arcpy.MakeFeatureLayer_management("DetCircles2.shp", "Details_lyr")
detailCircles = "Details_lyr"
# Set the base values for the position of your first inset map
# Locations of all the inset maps will be calculated based on these values
baseXpos = 3.0
baseYpos = 12.9
# Create objects for the layout elements that will be moving, e.g., notes and abandonment elements
notes = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "NOTES")[0]
abandonments = arcpy.mapping.ListLayoutElements(mxd, "GRAPHIC_ELEMENT", "ABANDONMENTS")[0]
triangle = arcpy.mapping.ListLayoutElements(mxd, "GRAPHIC_ELEMENT", "TRIANGLE")[0]
diamond = arcpy.mapping.ListLayoutElements(mxd, "GRAPHIC_ELEMENT", "DIAMOND")[0]
noteTitle = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "noteTitle")[0]
abandonmentTitle = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "abandonmentTitle")[0]
