I want to stack three different layers and group them by their own date field. For some reason, my Arcade code is working but no data is showing in the data table below. I am assuming this is a small tweak to the code but wasnt sure.
I currently have the following arcade code, modeling as a template from this presentation https://www.esri.com/arcgis-blog/products/ops-dashboard/analytics/enhancing-dashboard-elements-using-data-expressions-part-1/
var portal = Portal("https://planetscapeai.maps.arcgis.com/");
var alerts = GroupBy(
FeatureSetByPortalItem(portal,"9b11dda1c0804f13a72136a8bf71b93c",0,["*"],false),
["Date"],
{ name: "Alerts1" ,expression: "FID", statistic:"COUNT" }
var imagery = GroupBy(
FeatureSetByPortalItem(portal,"d70d948dd59c451bb56cc12a8f7aeb96",0,["*"],false),
["Date"],
{ name: "Alerts2" ,expression: "FID", statistic:"COUNT" }
var survey = GroupBy(
FeatureSetByPortalItem(portal,"f18f6b7a0447412083228d6ce554f042",0,["*"],false),
["CreationDate"],
[{ name: "Alerts3", expression: "objectid", statistic: "COUNT" }]
var combinedDict = {
fields: [
{ name: "Type", type: "esriFieldTypeString" },
{ name: "CompletedDate", type: "esriFieldTypeDate" },
{ name: "NumberOfAlerts", type: "esriFieldTypeInteger" },
geometryType: "",
features: [],
var i = 0;
// Loop through each FeatureSet and store its attributes
for (var m in alerts) {
combinedDict.features[i++] = {
attributes: {
Type: "Alerts",
CompletedDate: m["Date"],
NumberOfAlerts: m["Alerts1"],
for (var p in imagery) {
attributes: {
Type: "Imagery",
CompletedDate: p["Date"],
NumberOfAlerts: p["Alerts2"],
for (var j in survey) {
attributes: {
Type: "Survey",
CompletedDate: j["CreationDate"],
NumberOfAlerts: j["Alerts3"],
// Return dictionary cast as a FeatureSet
return FeatureSet(Text(combinedDict));
