i work on a python program for changing attribute in a xml. but when i test my script i've got a message who say :
SyntaxError Traceback (most recent call last) File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ast.py, in parse: Line 35: return compile(source, filename, mode, PyCF_ONLY_AST) SyntaxError: invalid syntax (<string>, line 11)
can you help me to fix the problem please?
import os
import sys
import xml.etree.ElementTree as ET
from xml.etree.ElementTree import Element
import arcpy
from arcpy import metadata as md
from datetime import datetime
# Script arguments...
Source_Metadata = [
arcpy.GetParameterAsText(0)]
# Local variables
# new purpose text
resTitle1 = "n/a"
jason = "PMMCU"
jemets = "GEMET - INSPIRE themes, version 1.0"
madate = "2021-11-15T00:00:00"
madate2 = "2010-12-08T00:00:00"
opendatanorme = "CC0, CC BY, CC BY-SA"
Pub = "publication"
Al = "GeoService"
reglement = "Selon reglèment"
commission = "Commission Regulation (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services"
conpass = "1"
domaine = "DQDomConsis"
balise = r'dqInfo/report'
att = "dimension"
valAtt = "horizontal"
type = "type"
newtype = "DQDomConsis"
balise2 = r'dqInfo/report/EvalMethTypeCd'
att2 = "value"
valAtt2 = "001"
balise3 = r'dqInfo/ScopeCD'
att3 = "value"
valAtt3 = "005"
# fonction ppour mettre à jour des valeurs
def update_metadata(root):
num_elements = 0
# Recherche de la balise depuis root
beta = root.find(".//" + balise)
if beta is not None:
print ('Les attributs de la balise ' + balise + " sont : " + str(beta.attrib))
if beta.get(type) is not None:
# L'attribut recherché existe
print ("L'attribut recherché existe (" + type + ")")
print ("Valeur actuelle : " + beta.get(type))
print ("Nouvelle valeur : " + newtype)
beta.set(type, newtype)
num_elements += 1
if beta.get(type) is None:
# L'attribut recherché n'existe pas
print ("L'attribut recherché n'existe pas (" + type + ")")
print ("Ajout de cet attribut avec la valeur : " + newtype)
num_elements += 1
else:
print("La balise n'existe pas")
return num_elements
num_elements = 0
zeta = root.find(".//" + balise2)
# balise de ressource quality report dimension
if zeta is not None:
# Affichage des attributs de la balise
print ('Les attributs de la balise ' + balise2 + " sont : " + str(zeta.attrib))
if zeta.get(att2) is not None:
print ("L'attribut recherché existe (" + att2 + ")")
print ("Valeur actuelle : " + zeta.get(att2))
print ("Nouvelle valeur : " + valAtt2)
zeta.set(att2, valAtt2)
num_elements += 1
if zeta.get(att2) is None:
print ("L'attribut recherché n'existe pas (" + att2 + ")")
print ("Ajout de cet attribut avec la valeur : " + valAtt2)
num_elements += 1
else:
return num_elements
geta = root.find(".//" + balise3)
if geta is not None:
print ('Les attributs de la balise ' + balise3 + " sont : " + str(zeta.attrib))
if geta.get(att3) is not None:
print ("L'attribut recherché existe (" + att3 + ")")
print ("Valeur actuelle : " + zeta.get(att3))
print ("Nouvelle valeur : " + valAtt3)
geta.set(att3, valAtt3)
num_elements += 1
if geta.get(att3) is None:
print ("L'attribut recherché n'existe pas (" + att3 + ")")
print ("Ajout de cet attribut avec la valeur : " + valAtt3)
num_elements += 1
else:
return num_elements
# get and save item metadata
for item in Source_Metadata:
arcpy.AddMessage("Item: {0}".format(item))
# get the item's metadata xml
item_md = md.Metadata(item)
metadata_xml_string = item_md.xml
# create an ElementTree object from the metadata XML string
root = ET.fromstring(metadata_xml_string)
# call the update_metadata function to modify the item's metadata
changes = update_metadata(root)
if changes > 0:
# get modified XML
updated_xml_string = ET.tostring(root, encoding="utf-8")
# import result back into metadata
arcpy.AddMessage("Saving updated metadata with the item...")
item_md.xml = updated_xml_string
item_md.save()
else:
arcpy.AddMessage("No changes to save")
arcpy.AddMessage('Finished updating metadata for all source metadata items')
# function to update purpose and credits in metadata
num_elements = 0
for child in root:
print(child.tag, child.attrib)
# modify purpose element's text
# there is only supposed to be one purpose element in metadata
# replace purpose element text if element exists
# if element doesn't exist, do nothing
purposeEls = root.findall(".//formatVer")
for element in purposeEls:
if element.text is not None:
element.text = resTitle1
num_elements += 1
purposeEls1 = root.findall(".//idCredit")
for element in purposeEls1:
element.text = jason
num_elements += 1
purposeEls2 = root.findall(".//useLimit")
for element in purposeEls2:
element.text = opendatanorme
num_elements += 1
purposeEls2 = root.findall(".//identCode")
element.text = Pub
num_elements += 1
purposeEls2 = root.findall(".//formatName")
element.text = Al
num_elements += 1
# add credits element to dataIdInfo parent, if the parent exists
# ISO allows many dataIdInfo groups; ArcGIS supports only one, so get the 1st
# ISO allows many idCredit elements, and many are supported in ArcGIS
# append a new idCredit element with appropriate text, existing elements remain
dataIdInfoEls = root.findall("./dataIdInfo")
for element in dataIdInfoEls:
if element:
newCreditEl = ET.SubElement(element, "themeKeys")
newCreditEl1 = ET.SubElement(newCreditEl, "thesaName")
newCreditEl2 = ET.SubElement(newCreditEl1, "resTitle")
newCreditEl2.text = jemets
num_elements += 1
newCreditEl2 = ET.SubElement(newCreditEl1, "date")
newCreditEl3 = ET.SubElement(newCreditEl1, "pubDate")
newCreditEl3.time = madate
num_elements += 1
# modif champ quality
dataIdInfoEls1 = root.findall("./dqInfo")
# for element in dataIdInfoEls1:
# if element.text is not None:
# newCreditcom = ET.SubElement(element, "report")
# newCreditcom1 = ET.SubElement(newCreditcom, "measResult")
# newCreditcom2 = ET.SubElement(newCreditcom1, "ConResult")
# newCreditcom3 = ET.SubElement(newCreditcom2, "conSpec")
# newCreditcom4 = ET.SubElement(newCreditcom3, "resTitle")
# newCreditcom4.text = commission
# num_elements += 1
if element:
newCreditreg = ET.SubElement(element, "report")
newCreditreg1 = ET.SubElement(newCreditreg, "measResult")
newCreditreg2 = ET.SubElement(newCreditreg1, "ConResult")
newCreditreg3 = ET.SubElement(newCreditreg2, "conSpec")
newCreditreg4 = ET.SubElement(newCreditreg3, "resAltTitle")
newCredit4 = ET.SubElement(newCreditreg3, "collTitle")
newCreditEll4 = ET.SubElement(newCreditreg3, "date")
newCreditEll5 = ET.SubElement(newCreditEll4, "pubDate")
newCreditcom4 = ET.SubElement(newCreditreg3, "resTitle")
newPass4 = ET.SubElement(newCreditreg2, "conPass") # type: Element
newCreditreg4.text = reglement
newCredit4.text = reglement
newCreditEll5.text = madate2
newPass4.text = conpass
newCreditreg.text = domaine
num_elements += 1
return num_elements
if changes > 0:
# get modified XML
item_md.save()
else:
arcpy.AddMessage('Finished updating metadata for all source metadataA items')
thanks
