WMTS with valid "time" dimension (according to OGC standards) can be displayed in ArcGIS Portal in e.g. a webmap (as layer or basemap). When using the same webmap as basemap in (a) Survey123 Connect or (b) Survey123 mobile app, the WMTS is not shown. I tested the WMTS without time parameter in all above mentioned apps - then it worked.
https://s.maps.strabag.com/custom/api/geoserverproxy/wmts?projectid=bim123czdet&time=2021-07-08&custom=true
The same issue occurs when using the webmap in ArcGIS field maps mobile app.
