I am getting a weird error trying to submit a survey in the web form. The survey was created in Connect and has a handful of required questions. If I fill everything out and hit "submit," it brings me to the top and says "Survey contains errors: 1. Press here to navigate to each error." If I click that bar at the top, it doesn't go anywhere or highlight any question. If I fill out the survey, but intentionally miss a required question, and hit "submit," the error still shows up, but after I click the error bar and correct the missing req. question, it allows me to submit.
I'm really at a loss for what's happening here, especially since the survey will successfully submit if I intentionally miss a question and then fix it. Connect form is attached.
