I need some help appending a csv to a hosted table in AGOL.
History: I have an exisintg hosted table published to AGOL. I also have an uploaded csv also on AGOL (not published, just uploaded)
The hosted table has no data, only field names - it is only a shell and is editable.
The idea is that eventually the hosted table will have its values updated - via a wipe and append. Hence the truncate.
As a test, I'm trying to append an existing csv that has been uploaded to AGOL to this hosted table.
The hosted table and csv have the same field names.
When I run my script, to attempt to append the csv to the hosted table, I get an error (see below)
My input script: (item ID's have been removed for privacy)
import os
from arcgis.gis import GIS
# Log into ArcGIS Online
gis = GIS('home')
#set AGOL item IDs
MSL_AGOL_Users_Table_ID = "AGOL item id"
input_CSV_table_ID = "AGOL item id"
#get MSL AGOL Users hosted feature service
MSL_AGOL_Users_Item = gis.content.get(MSL_AGOL_Users_Table_ID)
#Grab the MSL AGOL Users table and remove current data
UserTable = MSL_AGOL_Users_Item.tables[0]
UserTable.manager.truncate()
#append CSV to hosted table
source_info_csv = gis.content.analyze(item=input_CSV_table_ID, file_type='csv', location_type='none')
UserTable.append(item_id = input_CSV_table_ID,
upload_format = 'csv',
source_info = source_info_csv,
upsert=False,
append_fields=['Username', 'FullName', 'AvailableCredits', 'AssignedCredits', 'FirstName', 'LastName', 'Description', 'Email', 'IdpUsername', 'LastLogin', 'MfaEnabled', 'Access', 'StorageUsage', 'StorageQuota', 'OrgId', 'Role', 'RoleId', 'Level', 'Disabled', 'Tags', 'Region', 'Created', 'Modified', 'Provider', 'Id', 'ExistsInAD', 'ADAccountEnabled', 'ADAccountStale', 'Agency', 'Department'],
skip_inserts=False)
The errors I get, when executed in my ArcGIS Pro Notebook:
Exception Traceback (most recent call last)
In [109]:
Line 26: skip_inserts=False)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\layer.py, in append:
Line 2032: sres = self._con.get(path=surl, params={'f' : 'json'})
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in get:
Line 432: return self._handle_response(resp, file_name, out_path, try_json, force_bytes=kwargs.pop('force_bytes', False))
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in _handle_response:
Line 514: self._handle_json_error(data['error'], errorcode)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in _handle_json_error:
Line 536: raise Exception(errormessage)
Exception: Object reference not set to an instance of an object.
(Error Code: 400)
I've tried quite a few ways to get past this error but cannot.
Any help to get this to work?
