Hi
When updating a feature in offline field maps, when submit and sync, the Integromat scenario runs, but the array is empty in the iterator so no further steps occur.
When I make a second update to the feature and sync, the Integromat scenario runs, and this time the array has a value
This is because when syncing the second time, the update is pulled from AGOL that happened in the first sync.
I have tested this also by first making an edit in the feature service via the item\data page, then when I make the first update in Field Maps the integormat scenario runs, and this time the array has has a value.
Is this expected behaviour, or a bug? If it's expected behaviour how do I get Integromat to see a populated array the first time an update is made
Charlie
