My survey was created in Survey123 Connect and is intended for use in the web app. The end-user is required to put in their address.
This may sound like a silly question, but is there a way to geocode the survey submissions based on the address field(s)? I'm not including a map question. Right now the points are at 0,0. I'm interested in having the points geocoded because internally there will be an app with the ability to export the features (using the select widget). And, it wouldn't look right when viewing the app if the points were not in their correct locations.
