Does anyone know of a 3rd party, custom attribute table widget I can use to replace the default ESRI attribute table widget?
The default ESRI widget has been plagued with various issues for years. In may case, I don't know the exact trigger(s) but if any change is made to a web map or its web app, the attribute table widget crashes and fails to load. The "fix" seems to be to "reset" the widget by opening the widget configuration and waiting for the layer list to populate then closing it and saving the app. This is the case in both AGOL and Portal.
When you maintain over two dozen, highly dynamic production web apps, fixing the attribute table widget after every single change quickly becomes a full-time job in and of itself. I longer have the patients or the time to continue using this widget in my apps. I need something reliable. Any suggestions?
