I created a file geodatabase in ArcMap 10.8. I then created several raster mosaics and imported a Sentinel-2 image and various elevation layers. Everything worked fine. I then imported the ArcMap project with the raster layers into ArcGIS Pro 2.5. The project imported successfully including the layers, however when I try to access the geodatabase it appears empty. In both Catalog view and pane there's a message that says "This container is empty". Can anyone advise what I'm doing wrong here.
Thank you.
