Is it possible to use a webmap with the outbox? It seems the linked map is only used by the inbox and sent, as well as by the survey, while Outbox uses only the basemap.
This is to support a workflow of being offline for a long time - need to see the points they are collecting so they know where more samples are needed, also in context with their other assets, to be able to continue to collect effectively.
Would be great to know if this capability is coming in a future release or is there a way to set it manually at this point. Thanks!
Sue
