Hi, a while back, I don't remember how long ago, Survey123 did not use Location Services while in the background (i.e. when you tap the home button on an iPhone and left Survey123 in the background). Currently in the new update, when you leave it in the background it states that Location Services are running and there is a blue icon on the top notification bar next to the WiFi signal and battery percentage icons.
I tried looking into settings and there is no setting to turn off Location Services running in the background. This is causing significant battery drain for our users, especially those that are not tech-savvy enough to notice the blue icon and leave the location services running even though they are completely done with taking our survey.
Again I state that this was not the case in the past, where Survey123 only used location services while actively in the forefront of the device. Is there a fix for this? I do not see this setting anywhere on iOS devices. I've read in previous posts that the app is optimized to not drain the battery but that is simply not the case as while I type this post out it has lost another percentage while I did not use the device at all.
