Hi all,
I am trying to train and apply a Deep Learning model in ArcGis Pro 8.0. I installed all the required Python packages (now 289 packages installed and up to date).
I am working on WorldView-3 raster images (8 bands). I created a shapefile to delineate the objects I want the model to train on. There are about 50 objects with 3 classes (indicated as 0, 1, and 2 in a "code" field in the attribute table).
The model I am trying to use in the Mask R-CNN.
I used the Export Training Data for Deep Learning function in ArcGis to build my training dataset, selecting the RCNN Masks as Metadata format. The function works and exports image tiles as .tif format with the corresponding true label masks.
However, using this dataset in the Train Deep Learning Model leads to the following error (copied from ArcGis report):
Parameters
Input Training Data d:\Users\gcamp\Documents\OBJ_DETECTION\TRAIN_FILES_MASK_RCNN_ARCGIS
Output Model d:\Users\gcamp\Documents\OBJ_DETECTION\MODEL
Max Epochs 20
Model Type MASKRCNN
Batch Size 4
Model Arguments chip_size 224
Learning Rate
Backbone Model RESNET50
Pre-trained Model
Validation % 10
Stop when model stops improving STOP_TRAINING
Output Model
Freeze Model FREEZE_MODEL
Messages
Start Time: vendredi 5 novembre 2021 16:06:32
Failed script (null)...
File "d:\users\gcamp\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 297, in <module>
execute()
File "d:\users\gcamp\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 271, in execute
callbacks=[ProgressCallback(training_model_object, model_type, max_epochs, out_folder)]
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\arcgis\learn\models\_arcgis_model.py", line 739, in fit
lr = self.lr_find(allow_plot=False)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\arcgis\learn\models\_arcgis_model.py", line 574, in lr_find
raise e
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\arcgis\learn\models\_arcgis_model.py", line 571, in lr_find
self.learn.lr_find()
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\train.py", line 41, in lr_find
learn.fit(epochs, start_lr, callbacks=[cb], wd=wd)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\basic_train.py", line 200, in fit
fit(epochs, self, metrics=self.metrics, callbacks=self.callbacks+callbacks)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\basic_train.py", line 99, in fit
for xb,yb in progress_bar(learn.data.train_dl, parent=pbar):
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastprogress\fastprogress.py", line 47, in __iter__
raise e
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastprogress\fastprogress.py", line 41, in __iter__
for i,o in enumerate(self.gen):
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\basic_data.py", line 75, in __iter__
for b in self.dl: yield self.proc_batch(b)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\torch\utils\data\dataloader.py", line 345, in __next__
data = self._next_data()
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\torch\utils\data\dataloader.py", line 385, in _next_data
data = self._dataset_fetcher.fetch(index) # may raise StopIteration
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\torch\utils\data\_utils\fetch.py", line 44, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\torch\utils\data\_utils\fetch.py", line 44, in <listcomp>
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\data_block.py", line 651, in __getitem__
if self.item is None: x,y = self.x[idxs],self.y[idxs]
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\data_block.py", line 120, in __getitem__
if isinstance(idxs, Integral): return self.get(idxs)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\fastai\vision\data.py", line 271, in get
res = self.open(fn)
File "d:\Users\gcamp\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\arcgis\learn\models\_maskrcnn_utils.py", line 105, in open
lbl_name = int(self.index_dir[self.inverse_class_mapping[fn[k].parent.name]])
KeyError: '0'
Failed to execute (TrainDeepLearningModel).
Failed at vendredi 5 novembre 2021 16:06:36 (Elapsed Time: 4,10 seconds)
I tried many combinations of input parameters (backbone model, etc.), but the error remains unchanged.
Since the error message is unclear, I cannot figure out what is wrong with the function.
Any help appreciated! 🙂
