Ideally, I want a drop down box in Field Maps to filter another drop down box. I have a field called 'Codes', and each code has several 'Options' which are in another field. If a worker chose the Code 'Roofing', the very long Options list would be filtered to just show the Roofing Options.
I've spent a couple of days trying to see if there is a work around, and everywhere keeps saying that Filter in Arcade isn't possible yet. @Anonymous User, I saw you've talked about sub-types (https://community.esri.com/t5/arcgis-field-maps-questions/can-you-limit-the-drop-down-list-of-domain-values/m-p/1019329#M272) but I can't find any documentation about how to code this in Field Maps.
Is there really no work around? Do I just need to be patient? Does anyone know for how long?
