Hello All,
I am trying to view a 3D multipatch model in ArcGIS Earth Offline. I added my data (in state plane coordinate system) to a Global Scene and then created a mobile map package. I add the mobile map package to ArcGIS Earth on my desktop and the data is not visualized and I get a yellow warning signal next to the features (see screen shot 1). When I add the mobile map package to ArcGIS Earth on my mobile device it does not display, and all I see is grey squares (see screen shot 2).
I know ArcGIS Earth only supports WGS 84 coordinate systems but I was wondering with 3D mobile scene packages, if it was created from a global scene, would that/should that data still be able to be viewed in ArcGIS Earth. When I publish my 3D multipatch state plane features from a global scene to AGO, it displays correctly, and I can add it to ArcGIS Earth and it works perfectly as well. For what ever reason when I put that same data set to a mobile scene package from a global scene it does not display in ArcGIS Earth. It is critical that I am able to use this data set offline!
Thank you very much and I look forward to your response.
Zach Jaffe
