Hello! Is there a way that a survey can be automatically removed from a mobile device after the survey as been closed? I've ran into issues where our organization will publish a new survey (example, 2020 Inspections to a 2021 Inspections), and the older survey, while being closed will still open/ work as normal, until the user tries to send the survey in, stating the survey is closed or user no longer has access. I know that the surveys can be manually deleted, but this method would be easier for larger groups and different managers to reduce re-entering or redoing surveys again, in another form.
Thanks for all advice or help!
