I've created a survey using Survey123 Connect. It has repeats that generate related tables. When I export to Excel my worksheets are out of order and not labeled using the name field. Also, if a team member exports to Excel the worksheets are labeled different from if I export them. I've tried using the bind:esri:fieldAlias and it doesn't seem to work either. Does anyone have any suggestions to make this work?
