There is a Python script intended to create a UPDM geodatabase, it receives several parameters, among them, database admin user, database dataowner user, and their passwords.
The script runs using the ArcGIS Pro 2.8 Python, it starts its process, creates the database, as well as connection files (.sde). In some point of the script, it has been created different structures: tables, relationships, domains, etc. but then it failswhile calling:
arcpy.da.ListDomains(self.database)
The error is quite weird (at least for me):
ERROR 1: Can't load requested DLL: C:\ArcGISPro\bin\gdalplugins\gdal_MG4Lidar.dll
1114: A dynamic link library (DLL) initialization routine failed.
11:51.29.583441 ERROR C:\temp\Installation\Data\DataOwner.sde
11:51.29.589433 ERROR ['Traceback (most recent call last):\n', ' File ".\\Arcpy\\InstallDataModel.py", line 95, in main\n', ' File "C:\\temp\\Installation\\Arcpy\\Classes\\JSONGeoDataModelClass.py", line 598, in create_domains\n existing_domains = arcpy.da.ListDomains(self.database)\n', 'OSError: C:\\temp\\Installation\\Data\\DataOwner.sde\n']
Furthermore, the ArcGIS Pro Crash Window appear 4 times (probably one time for each crash in the request of the gdal_MG4Lidar.dll).
In this point of the execution, this line has been called several times, the script has been using the sde connection file for several actions, inside the script there is no direct call to GDAL libraries (I assume it is an internal call from the ArcGIS Pro libraries/modules) and despite the message, I can verify the existence of the sde file and even use it in a new ArcGIS Pro instance.
What could be the reason behind this error? There is a way to surpass it?
