HI folks,
Has anybody received the following error when attempting to open an attribute table in an FGDB in ArcGIS Pro?
This error is showing up when opening attribute tables associated with featureclasses in several of my FGDBs. In all cases, the featureclasses have fields associated with editor tracking (e.g., Creator, CreationDate, Editor, EditorDate). The EditorDate and CreatorDate fields are the only date fields in the featureclass. I am getting the error whenever I try to open the attribute table regardless of whether there is data in the featureclass or not. I have tried deleting all data out of the featureclass, but still received the same error.
I can open the attribute tables just fine in ArcMap, but not in ArcGIS Pro.
The only reference to this error that I found was at: https://support.esri.com/en/technical-article/000024929.
Unfortunately, this reference doesn't seem to pertain as I am getting the error even if the table is empty.
I can provide a blank FGDB with the affected featureclasses if anyone is interested.
Thanks in advance!
