I was wondering if it was possible to use FeatureSetByRelationshipName to calculate fields in a related feature class?
What I want to do is carry the values from a field in featureclass1 to an empty field in featureclass2. I can successfully achieve this in a popup in AGOL, but I want to do be able to achieve this in Field Calculator, and then ultimately Python to automate the process.
At the moment, I am using the below expression for the popup, but it doesn't seem to work in Field Calculator:
var relatedrecords = FeatureSetByRelationshipName($feature,"[relationship_name]")
for (var f in relatedrecords){
return f.[field_name]
TIA
