I am trying to apply attribute-driven client-side styling to a custom vector tile layer (published to ArcGIS Online from Pro) in the ArcGIS JavaScript API v 4.20 . Specifically, I would like to use color stops to style polygon fill-color based on an attribute. I have been able to use setPaintProperties to change the default color of the layer (code below). However, I have not been able to set the "property" to an attribute, as described in the Mapbox style layer documentation that is linked from the setPaintProperties documentation. I have successfully used this approach with Mapbox GL using vector tiles, but am unsure if it is possible in the JS API v4.20.
This is the code I'm trying to get to work. When executed, it applies the red default color.
styleMap(){
const paintProperties = vtLayer.getPaintProperties("myLayer");
var fill ={
property: "myAttribute",
default: 'red',
stops: [
[0 , '#a1a1a1'],
[10000, '#ccece6'],
[200000, '#99d8c9'],
[500000, '#66c2a4'],
[1000000, '#2ca25f'],
[15000000, '#006d2c'],
paintProperties["fill-color"] =fill;
vtLayer.setPaintProperties("myLayer", paintProperties);
Is this supported and/or are there plans for it to be supported in future versions?
Erik
