I am struggling to create a survey with both polygons and related points that targets/edits an existing feature service using Survey123 Connect version 3.13.
I am trying to model a dataset where multiple points features are related to (nested within) polygon sites areas and a polygon should be able to have a 1:M relationship with the points. This is to support field surveys of existing sites that contain features and will eventually be populated with existing data. For now, I'm just trying to test this capability. I was able to create a new survey with a polygon/geoshape and repeat geopoints points and now I'm trying to create an existing feature service to see if it's possible to set this up to edit data in an existing feature service. Using ArcPro, I have successfully created a polygon and point feature class with a 1:M composite relationship and published it as a feature service that supports edits with global ID's (I followed these two resources: https://www.youtube.com/watch?v=Fo9tP9qkm8k and https://community.esri.com/t5/arcgis-survey123-blog/how-to-enable-supportsapplyeditswithglobalids-on/ba-p/893977).
It's not working. While the test feature services looks correct in AGOL (related data), when I try to build a survey off the related features using Survey123 connect, the related records do not come in the the XLS or form. The survey has only a geopoint and no repeats. I was hoping that I would get a survey with a geoshape question and a repeat containing the geopoints. Does anyone else have experience with this or can anyone advise?
Thanks in advance!
