var features = FeatureSetByPortalItem( Portal('https://www.arcgis.com'), '98cca0ba2d58470b96061faa24421e66', 0, ['ID_FCC', 'RestorationArea','RestorationType','Project','HabitatRestored','Date'], false );
var filterFeatures = Filter(features, "RestorationType <> 'Riparian'");
var distinctFeatures = Distinct(filterFeatures,['ID_FCC','RestorationArea']);
return distinctFeaturesThe above feature set return only unique combination between ID_FCC and RestorationArea (witch is what I want) columns together with ROW_ID
But I want to return also the fields from FeatureSetByPortalItem (eg 'RestorationType', 'Project', 'HabitatRestored' and 'Date')
Apparently Distinct Function remove other columns
Is there a way to rejoin all the fields base on ROW_ID?
Adrian
