I have a stream feature class with many features that form a chain, one after the other with no side streams coming in. I am trying to create a clean feature class of stream segments by combining segments that meet at their endpoints using the Unsplit Lines tool. The output feature class does combine features, creating just one feature for each section between stream confluences... but the problem is that many of these are now multipart features. Why does this happen - is it a bug?
To make sure that it wasn't a problem with the input data, I first ran the Multipart to Singlepart tool to get a feature class that would have no multipart features as input. I then used the field calculator to confirm that the features each had only one part. I then ran the Unsplit Lines tool on the result and the same thing happened - the output features had multiple parts. I'm using ArcGIS Pro 2.8.1
