We have found that there may be an issue with the pandas install when using Python for ArcGIS 1.9.0 and ArcPy 2.8 together in a conda clone. Posting to see if it affects and/or helps others.
I am using Conda 4.10.0 and ArcGIS Pro 2.8.2 is installed on the machine.
Solution first:
The following works (update pandas):
conda create -c esri -n arcgis-pro --yes --offline python=3.7
conda install -c esri --yes --offline arcgis=1.9.0
conda install -c esri --yes --offline arcpy=2.8
conda install -c anaconda --yes --offline pandas=1.1.3
Steps to reproduce breakage:
New clone, install Python for ArcGIS 1.9.0 (works ok at this time)
conda activate arcgis-pro python
>>> import arcgis
>>> exit()
Install ArcPy 2.8 (breaks Python for ArcGIS 1.9.0)
python
>>> import arcgis
>>> !!explosions!! (see error below)
Error:
If pandas is not upgraded/reinstalled after installing ArcPy 2.8, we received the following error when attempting to use Python for ArcGIS 1.9.0
(arcgis-pro) PS D:\> python
Python 3.7.10 (default, Feb 26 2021, 13:06:18) [MSC v.1916 64 bit (AMD64)] :: Anaconda, Inc. on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import arcgis
File "<stdin>", line 1, in <module>
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\__init__.py", line 4, in <module>
from . import features, geoanalytics, geocoding, geometry
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\features\__init__.py", line 33, in <module>
from . import enrich_data
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\features\enrich_data.py", line 10, in <module>
import arcgis.network as network
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\network\__init__.py", line 7, in <module>
from ._layer import (
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\network\_layer.py", line 10, in <module>
from arcgis.mapping import MapImageLayer
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\mapping\__init__.py", line 8, in <module>
from ._types import (
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\mapping\_types.py", line 30, in <module>
from arcgis.widgets._mapview._traitlets_extension import ObservableDict
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\widgets\__init__.py", line 2, in <module>
from arcgis.widgets._mapview import MapView
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\widgets\_mapview\__init__.py", line 1, in <module>
from arcgis.widgets._mapview._mapview import MapView
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\arcgis\widgets\_mapview\_mapview.py", line 38, in <module>
import pandas as pd
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\pandas\__init__.py", line 22, in <module>
from pandas.compat import (
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\pandas\compat\__init__.py", line 23, in <module>
from pandas.compat.pyarrow import (
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\pandas\compat\pyarrow.py", line 9, in <module>
_palv = Version(_pa_version)
File "C:\ProgramData\Anaconda3\envs\arcgis-pro27\lib\site-packages\pandas\util\version\__init__.py", line 339, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
