Hi, when I first published my survey I couldn't find the folder it published to - I completely forgot that the folder is automatically given the suffix 'Survey' before the actual survey title. So in ArcGIS contents, I made a new folder and found the survey form in the 'All my contents' section, and moved it to the new folder.
After this was done, I found the original folder that it published to. I deleted this empty folder just to tidy things up, and didn't realise this would cause issues.
Now that I've made a minor change to my survey, it won't re-publish. The loading symbol goes on and on and never actually reaches the publish completion. I have determined that the moving form to another folder has caused this issue... Since the original folder it published to is deleted, how can I fix the issue?
I saw in this community question page that I could add the new folder's ID to the survey's .iteminfo file. However, the .iteminfo file of my survey doesn't have a section for the ID or the folder ID...
Any advice would be really appreciated!
